I live in Ohio and I dormant overseeded in early January. So far, it has worked wonderfully. A lot of the new seed is coming up but some weeds have started to germinate as well. I normally put down some pre-emergent, like Halts, but I waited to let as much of the seed to germinate as possible. The snows and wet springs made this method of overseeding work fantastic in my opinion.
Does anyone know when is the earliest I could put the pre-emergent down? I would love to be able to use this dormant overseeding method every year, yet still prevent crabgrass and other weeds from popping up in late spring and all through summer.
J. Musser
  • 52,241
  • 122
  • 333
Evil Elf
  • 3,205
  • 25
The time out period will be listed on the label but is commonly six weeks or more. With the climate changing quickly and causing ground temperatures to rise you have to be diligent to apply at the right time, too late does no good.
From this professional in Georgia
Crabgrass seed, you see, germinates when spring soil temperatures tend upwards from 50 degrees F. Weed scientists use 52 degrees F. at one-half inch deep as the trigger point for their application of pre-emergent herbicide.
Check to see if crabgrass is sprouting already and try a test patch that you have overseeded.
kevinskio
  • 62,221
  • 167
It's tricky dormant seeding and then waiting for seed to germinate to put pre-emergent down. If it is warm enough for the new seed to germinate, it's warm enough for crabgrass to do the same.
A product such as Tupersan can be applied to prevent crabgrass without preventing the grass seed from germinating. It is expensive and only lasts for about 30 days, so then you could apply another round of pre-emergent but you probably will have to post kill crabgrass then.
  • 7,289
  • 81
user13466
There are several modes of action in pre-emergent herbicides, but they all have one thing in common, which is targeting young, immature plants that are still dependent on the parent seed.
From my answer here:
I'd wait until the 3 leaf stage (where most of the seedlings have 3 blades each). This will ensure that they are finished taking nutrients from the old seed, and are mature enough to live independently. You could probably do it before that point, but when working with herbicides, safe is always better than sorry.
Doing that, you should also be in time to prevent the first crabgrass, as your seeded lawn should reach this stage far earlier in the spring, while the temperatures are still cooler.
J. Musser
  • 52,241
  • 122
  • 333
Sorry, I probably won't answer your question. My advice is to overseed after (weeks) you put your pre-emergent down. The point is that you cannot control when the weeds and crabgrass will germinate: when springtime temps turns ~50deg. If you overseed around that time, your grass will attempt to germinate at that time too. If you place a pre-emergent around then, it will stop both good and bad seeds from germinating.
user446
  • 229
