20
It doesn't seem like there's any process that would kill the kernels, as they're just being dried out. So would it be theoretically possible to grow the kernels into full corn plants? Would there be any difference between the kernels found in commercial, microwavable, bagged popcorn and corn kernels sold specifically for planting?
Throsby
  • 1,509
6 Answers6
17
It is possible to grow plants from the kernels you get for making popcorn, but remember this is a corn that isn't any good as sweet corn. it it very starchy and not sweet. it would only be good to use for more popcorn.
Here is a quick tutorial on germinating the seed.
In essence, what they recommend is the following:
  1. Get the plain kernels for home made popcorn from the market (unflavoured).
  2. Place the kernels in between damp sheets of kitchen paper to germinate.
  3. The kernels that have germinated should then be planted out into the ground in blocks of at least 3 x 3 (as corn is wind pollinated) and spaced at roughly 1' apart.
  4. Keep watered in dry spells.
  5. Leave the ears of corn on the plants until the leaves surrounding the corn have browned.
  6. Bring the ears in to dry out further.
  7. Once fully dried, twist off the kernels to use as you would with store bought.
N.B. A great tip, if your patch suffers from rodent or squirrel attack (they do love corn), is to place empty soda bottles over the ears of corn with ventilation holes punched into it so that you don't encourage mildew to attack the corn.
Patrick B.
  • 4,516
  • 42
  • 66
AvieRose
  • 1,528
It is possible to do, but your results will vary. The stuff you buy for food popcorn isn't specifically grown for seed; it may be an F1 hybrid and the generation that you grow out may not produce the same as the parents. (This is probably what happened to @michelle -- she mentions that the results were unpredictable.) If you just want to try it as an experiment, go for it, but if you actually want popcorn that will grow predictably, you can buy popcorn varieties, e.g. Pennsylvania Dutch Butter Flavored Popcorn.
bstpierre
  • 41,932
  • 118
  • 240
Yes, it should be possible. I've never tried Orville Redenbacher, but I have grown other grocery store popcorn and it grew just fine. The only problem for me was that the results were kind of unpredictable. The package I grew from said it was baby rice popcorn. I've grown baby rice before, and expected the plants to be 5 feet tall or so. The plants that grew from the grocery store seeds were closer to 10 feet tall - very surprising!
michelle
  • 9,569
I germinated all the popcorn kernels I tried. I will see if they grow into corn stalks. They were organic popcorn from the grocery store. I put a folded up paper towel in the bottom of a one cup measuring cup and soaked it with water. I put the corn in and put saran wrap on top in a warm place and they germinated in one day. I planted them into a peat pellet. Now waiting for more growth.
The quick answer is: It depends, but you probably won't get the same product as the one you bought.
The other answers really do a good job breaking this down. Growing something from a commercial product would come with two questions that you likely don't know the answer to from the packaging.
The first is: Did the seeds you bought come from hybrid plants? For corn specifically, the answer is probably yes. Most conventional, commercial growers use hybrid seeds because they have higher yields and since they are in the business of producing big yields, they likely are. When you plant the seeds of hybrid plants they "don't grow true" to the original plant which means that the offspring will be different from the parents - they be weaker, smaller, more susceptible to disease, or actually better! but likely worse.
However, if you bought from a grower who used an heirloom or landrace variety, this may in fact "grow true". That is, resulting (corn) plant would grow just like its parent plant(s) without the problems that come with F2 (or second generation) hybrid seeds.
The second factor is: Were the seeds irradiated? This is probably not the case for seeds (corn) that was grown in your country of origin, but may be the case for imported crops. Radiation is used on some imports with the express goal of killing the seed/any bacteria/fungus/disease etc that it may harbor. This would kill the corn seed and may mean that it won't grow.
The easiest, best way to grow popcorn generation after generation would be to choose an heirloom variety from the internet or from someone in your community who already has expertise and can suggest a good variety for your growing conditions. And remember, corn is wind pollinated so you have to grow a 10ft x 10ft plot (~3m x 3m) to ensure good pollination.
Throsby
  • 1,509
Corn is a kernel not a seed. However, it can be planted in the ground to grow corn stalks. My friends have been able to grow corn this way. Have fun gardening!
