I need to clean and restore an old olive plantation which was not cultivated for around 20 years and is now covered with weeds, bushes and spruce tree. I'm new to olive trees but have clean almost everything. But one "pest" bothers and comes back very quickly. It is a plant Smilax aspera which so far I was unable to eradicate. It grows very quickly and is capable to cover and suffocate whole olive tree.
What is the best way to get rid of Smilax aspera?
Initially I thought to do everything in an ecological way, but now this Smilax aspera is very resistant and I'm comfortable to use chemicals. Reason (frustration) for this is that olive plantation is far from road access, 1200 m (6000 ft) on very difficult to walk Mediterranean rocky terrain and even when Smilax aspera is removed from under the olive trees, it grows from nearby dry walls as on this image: smilax aspera from a dry wall
What other options do I have? Would burning and use of fire remove it permanently?
ssasa
  • 233
I've frequently used 3 different organic herbicides (link to my site) in the past with good results. They work by drying out the plant foliage. How it was explained to me by one of the manufacturers when I tested 2 of them on my lawn is: Plants need their leaves to create energy. If you keep removing their leaves they will use reserves from their roots to grow back but repeated application eventually depletes the reserves in the roots.
Flame weeding is another option. You're not trying to burn the weed, just damage it's leaves so that the leaves dry out. That might be a better option since you can't access the area by road.
Or you can just keep cutting it like you are but you need to do it every week or two.
Smilax Aspera is also known as rough bindweed. You might be interested in reading this document on organic control of field bindweed. Different family but similar name and characteristics.
This article on killing thorny smilax indicates using chemical controls is also difficult and timing is critical. It also recommends digging out or cutting down frequently.
  • 27,360
  • 59
OrganicLawnDIY
  • 8,567
  • 49
Fire does not kill weeds permanently if they are big enough, I would guess no but I do not know. I was going to suggest an alternative to find a more aggressive ground cover to push it out, but I just searched for something and it does not seem like there are too many more aggressive than what you got. Maybe get 1000 caterpillars to hold the front lines.
Four_lo
  • 600
