Spring onions (or scallions) can be re-grown in water by saving the roots and placing them in water and, as the article in the link suggests, these re-grow in to full spring onions within a matter of days.
My questions are:
  1. Are spring onions grown in this way as nutritious as those grown in the ground (because they may have less access to nutrients as they are not grown in soil)?
  2. Are they thought of as being as tasty?
Danger Fourpence
  • 1,348
I've grown them both ways. I've never had any problems with them not growing well in the ground, no matter how much I cut them back. In fact, they grew so well, I actually decided to mow them down, and compost them over the summer. One nice thing, is they will flower and you can then harvest the seeds if you want to keep growing more.
I've never noticed a flavor issue with them being grown in water either. I regrew them twice in water, then planted them in the ground.
thomasw_lrd
  • 343
I can't speak about regrowing these in water, but I will share what I do which is similar.
I regrow these by cutting them off about half an inch above where the white section ends and planting them directly into the ground. This might solve the issue you mention in point 1.
Once planted in the ground you can continue to harvest by cutting back and take what you need leaving the plant in the ground to grow. However, one problem with doing this is that the new growth will not grow back to the same size as the original plant so you gradually get less and less from the plant. I would suggest you can only harvest another 3 or 4 times like this until the regrowth is too small and thin.
Another problem with using the root for replanting is that the root has the strongest flavour. So from the first use you are already discarding the best part.
Considering that a bunch of these costs about $1 you are not doing much in terms of sustainability. I would suggest if you wanted to save money then I would go out and buy a packet of seeds.
However, if you can be bothered to put in the effort, it is actually worthwhile if you can get 100 of these planted in the ground together. It uses very limited space and it is very convenient to be able to take these as needed rather than going to the store if you run out.
going
  • 6,412
  • 37
  • 64
