I have an avocado plant in my outdoors balcony. It's been growing nicely, but there are small brown dots/holes in the leaves for some time now. I don't see anything in the underside of the leaves, and up until now new, healthy looking leaves have continued to sprout, but I'm concerned that it will not stay healthy.
What does it have? What can I do?
The avocado tree from above
A closeup of the leaves
UPDATE:
It's been months since I asked this question. The avocado's leaves continue to look bad, but it continues to put out new ones. I've attached a new picture of the current state as well as the trunk, in case the brown things on the trunk aren't harmless or natural (I hadn't noticed them before, because I was preoccupied with the leaves)
another close up of the leaves
This is the trunk, April 2014.
The trunk
Eyal
  • 931
Plants live in an uneasy balance with fungus, virus and bacteria. Sometimes they coexist, sometimes one attacks the other. The symptoms I see look like a soil borne infection caused by a stress to the plant.
One possible cause for this is overwatering. Underwatering tends to produce large areas of dead tissue in the leaves which I don't see here. If you think overwatering is possible just try a drier watering regime and see if the new growth is healthy.
Edit: Eyal asks about spider mites. This answer Why are these white dots appearing on my citrus and avocado trees and the leaves getting pale? is about avocados and citrus and has more detail about identification and control
kevinskio
  • 62,221
  • 167
It can be several things. I have to look at the back of the leaves to know for sure. My guess is:
Spider mites if there are red dots
Thrips or whiteflies if there are white dots on the back
It can be sun burn from misting if the back looks the same
user3084006
  • 451
I’m a bit late to the game, but I found your post when researching the same issue with my avocado tree. I spoke to an arborist and he said these are not mites but rather leaf burn - your tree is not getting enough water and as a result the light is able to burn the leaves. Deep water once a week and it should prevent future burn - cut off the burnt leaves to keep the tree from wasting energy on trying to repair those and it should do much better after a few weeks.
Claire
