17
Virtually all cultivated peppers are C.annuum, and I've had a lot of success growing these from seed. (I also usually buy 3-4 plants locally each year but selection is usually very limited)
I soak my seeds using a salt petre solution before sowing. This is recommended particularly for those that are harder to germinate (eg. chiltepins). Here in North Texas I usually get a small crop before the height of summer, and then the main crop September-November. All are grown outside, full afternoon sun. I used to use containers a lot, but I'm finding raised beds produce much bigger plants - probably due to water and root space.
Anyway, this is the second year that I have tried to grow C.frutescens varieties. Last year I tried Tabasco and Twilight. This year just Tabasco. Both years I've had poor germination rates (5 out 50 seeds this year). Plants never grew very big last year. This year they are definitely a lot smaller than the Anchos and Gypsies which were sown on the same day.
How can I improve their growth (with a view to more fruit in Autumn), and how can I improve the germination rate?
winwaed
  • 20,513
  • 65
  • 118
To improve germination, you might try an indoor start for the sake of control. Although I'm guessing North Texas is a pretty ideal place to grow peppers, hot housing the seeds and metering the light and water can aid you.
  • Rainfall may play a part in your problem (probably not unless you're near a soot mill), as would many tap waters. However it is remarkable how big an assistance distilling your water beforehand can have on sprouting and the quality of the plant (i.e. bottle water in jugs at your house from the tap; let sit a few days then use to water plants).
Further: To improve pollination, add some more flowery plants, ground cover, or vines around them. Basically get better seeds capable of germination by recruiting bees and birds with better looking flora. Containers will produce smaller plants and fruits and harvests. Also you can add coffee grounds at the plant's foot to increase acidity (which supposedly improves the heartiness of the plant an fruits).
winwaed
  • 20,513
  • 65
  • 118
mfg
  • 2,332
