I asked here a few weeks ago about repairing a hole in a soaker hose, and finally got around to doing it this weekend.
The initial repair went fine: I spliced in a section of regular hose and it is working great. However, when I turned the water on to test, I found a second hole. :( This one is—so far—resisting my efforts to repair it despite using the same method and parts. I'm getting leaks galore.
These hoses were put in by a landscaper about eight years ago. They were totally buried originally, but some areas have worked their way to the surface. Others are still buried and held down by roots that have grown over them. We've had a puppy for the last year who has dug up the hose in a few spots and probably made both of the holes. They look suspiciously like tooth marks - he probably bit the hose in such a way that one of his canine teeth lined up with a hole that was already there.
My question is, should I keep trying to fix it, or is this hose at the end of its life anyway? It looks fine, and I would have to cut through a lot of roots to get it out, so I would rather not. But I also don't want to keep messing with this if the hose is about to give up the ghost.
janineanne
  • 351
Replace it with drip emitter tubing. Soaker hoses suck. They put out more water in the start of the hose than they do at the end, leading to inconsistent watering that can hurt your plants.
With drip emitter tubing, drip emitters are molded into the tubing. The emitters should be pressure compensating which ensures that you get even distribution throughout the length of the hose.
The rainbird 1/2" drip emitter tubing also are designed to prevent clogs.
They're not much more than soaker hoses, especially if you need a lot of feet. You have to get a drip kit that fits on your faucet. Contains a pressure regulator valve and filter. They have these for sprinkler heads too. You should really be using a pressure regulator with your soaker hose too. Might be part of the reason why it needs repair.
OrganicLawnDIY
  • 8,567
  • 49
a flat dual stream soaker hose doesn't respond to most of the couplings available for the single stream variety. A possible solution- insert a suitable sized gas line hose ( a poly type that has been wiped with a silicone-to aid with the insertion into each of the severed pores ( all 4) join- tape with ready-fix type plumbing tape- then secure with an adjustable clamp_ within the normal range PSI exerted for a soaker hose of say--- 25 yds- no problem and should do the trick .... cheaply. you're welcome to this tip frank
frank
Not sure where you are, but if a soaker hose were left buried for one season here, in the Pacific Northwet, it would be crumbling bits not worth saving. If it has been eight years and you can still identify the hose, you must be somewhere very dry.
Brand new, medium duty soaker hoses are about $12 for 50 feet. It would be instructive to figure out what your time is worth when repairing that hose. My guess it is a lot less than you make at your day job.
wallyk
  • 154
I don't think you should waste the time saving a cheap soaker hose. With the roots going through it that just sounds bad. I think you should think about purchasing a drip hose. Roots don't grow through drip tape like they can through the porous material of a soaker hose. The drip hose I use is easy to use like a soaker hose and is about the same price, but it works much better. It will last a long time if your puppy doesn't chew it up. I use this.
