12
I planted strawberries a couple of years ago in a small patch of my back yard (in Sacramento, CA) and this year they are finally producing lots of strawberries. However, something is eating "divots" into them, as if something scooped out maybe a quarter to a third of the strawberry.
I have netting to keep out squirrels and other larger critters. However, many of the strawberries have divots eaten into them and I found one or two of these with what looked like a small black worm in them. The worm was maybe 3/8" long and less than 1/16" wide and its body looked smooth and featureless to my unaided eye.
Does anyone have an idea of whether these are the creatures that are eating my strawberries? If they are, what can I do to stop them? If something else is eating them, what could it be and what can I do about it?
Thanks for your help.
Ambo100
  • 765
eipi10
  • 687
This site describes (with copious pictures) the problem you are having.
A possible solution from the site:
Andrea from LifestyleBlock suggested I try using a solution of apple cider vinegar and spray the strawberries several times a day. Since I only had white vinegar I used that instead. The mix I did was 1 tablespoon vinegar to a litre of water. For 5 days now I have been diligently spraying the partially ripe strawberries and it seems to be working.
Bill
  • 506
My strawberries were damaged in the same way as yours, last year. The culprits proved to be Strawberry Seed Beetles (black, about 1cm long), which were living among some weeds nearby. They remove seeds from the outside of the fruit and also eat into it. I had netted the bed to protect it from birds, but had failed to weed around it - and these beetles are also attracted to weed seeds!
A slug killer would see them off, but it is not advisable to use chemicals near harvest time (and perhaps, like me, you are an organic gardener). I suggest you (1) make sure that nearby weeds are kept down,(2) clear away any dead leaves and garden rubbish,and (3) sink some jam jars into the soil around the bed - a lot of the beetles will fall into them, which will reduce their numbers. It may also be worth finding out if there is an organic slug repellent that would be effective against them, which I intend to do myself.
Mancuniensis
  • 14,334
  • 50
  • 85
