On my 2000 Jaguar V6 3Lt I replaced the clutch friction plate and slave cylinder/thrust bearing. After bleeding the clutch, the pedal is hard frozen and will not depress. I flipped the clutch wrong way but still nothing doing. I put back the clutch. Bled again no joy. Car has 2000,000km
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 259
  • 508
Have you put a brake hose clamp on the flexible hose of the clutch slave pipe and forgotten to remove it? Try disconnecting the pipe going into the slave cylinder and place a finger lightly over the end of it. Now have an assistant pump the clutch pedal, making sure the system is topped up with fluid. If the pipe pumps out fluid whilst disconnected then you can OK the master cylinder. Check that the small round seal is on the end of the pipe correctly and not adrift and blocking the fluid entry into the slave/concentric cylinder, they can come adrift. If OK, re-connect the pipe and try bleeding the clutch by closing the bleed nipple and pumping up system pressure, hold the pedal down and then open the bleed nipple, close the bleed nipple. Do this two or three times, or until the air in the system is bled. If the clutch does not now work correctly then you have re-assembled the clutch assembly incorrectly, which means the gearbox out again to rectify the fault.
Allan Osborne
  • 6,749
