The 2006 Infiniti G35 would crank but not start after a transmission replacement. I found 2 transmission codes. U1000 which is a CAN bus code and P1815 which is the manual shifting code. It is an automatic transmission with fairly low mileage.
Does anyone know if it may need a TCM reprogram or why it doesn't start after the auto trans replacement?
DucatiKiller
  • 32,976
  • 150
  • 267
josephpark
The CANBus error is key here. Something is shorted, broken or not connected.
The suspect electrical components are:
  • Manual Mode Switch Circuit
  • AT Shift Selector Assembly
  • Wire Harness and Connectors between components
For more diagnostic info, check out this thread: http://www.infinitifx.org/42-2nd-gen-2009/20401-transmission-problem-different-one.html
Especially posts 8 through 11.
kmarsh
  • 2,169
  • 37
