I have a Toyota Premio 260 model vehicle, anybody please help me to pair my extra smart key to my vehicle.
your help highly appreciated.
I found this information on a Toyota forum. It is from Toyota TSB dated November 9, 2007 (TSB#EL009-07). It works with a lot of different Toyota models for 2007-2008 and may work for yours as well. (NOTE: If it doesn't work, let me know and I'll delete this answer). It appears fairly complicated and time critical (time during/between steps needs to be done accurately).
Begin With:
Driver's door open and unlocked & key out of ignition
NOTE: Steps 2 and 3 should be performed within 40 seconds
NOTE: Steps 4-6 should be performed within 40 seconds
1 time for ADD mode
2 times for REWRITE mode
3 times for CONFIRMATION mode
5 times for PROHIBITION mode
NOTE: If CONFIRMATION or PROHIBITION modes have been selected, opening the door will complete the procedure.
A - Press both transmitter LOCK and UNLOCK buttons simultaneously between 1 and 1.5 seconds and release.
B - Within 3 seconds of step A, press the transmitter LOCK button from more than 1 second and release.
If the transmitter has been successfully programmed, the power locks will cycle "lock" to "unlock" once at this time.
If there are problems with the transmitter or the procedure up to this point, the locks will cycle twice. If this occurs, verify that you have received the correct transmitter, and then repeat the above procedure.
C - If multiple remotes are to be reprogrammed, repeat steps A and B
Open to driver's door to conclude programming mode
If you make an error during the programming mode, turn the ignition key to "ON" and back to "LOCK" to erase entered steps.
This procedure works for the following;
