On my car (2005 Dodge Grand Caravan) when I fill up my gas tank, almost immediately afterwards pulling out of the gas station my van sputters, misses, hesitates, call it what you will. The past couple of times the engine has actually stalled as well.
This is very short term. After this quick event it is then fine for the rest if the tank of gas.
Any thoughts on what could cause this?? Thanks!
EDIT
Some clarification on the symptoms, after I pull out from the gas state a few seconds down the road it's about a half second sputter/hesitation from the engine. And then it recovers. And then another few seconds later, the same hesitation will happen.
This is going from a really empty tank to a full tank. I always fill it up, and let it go down to almost empty (a few gallons left in the tank when I refill).
Thomas Stringer
  • 419
This sound similar to what I have experienced when there is rust or other "crud" in the bottom of the gas tank. Letting it get VERY low then filling it will stir up the "crud" and allow it to temporarily clog things up until it settles back down.
To confirm if this is whats happening, try filling up before the fuel level drops below half a tank. Do that a few times and see if it improves. By not letting the tank drop below 1/2, you create a buffer that prevents the introduction of new gas from disturbing the "crud" that has settled in the bottom of the tank.
pierce.jason
  • 331
When the tank is going to be completely filled the proper procedure is to allow the pump to shut off automatically. Add no more fuel after this initial shut off. Over filling the tank by filling to "the brim" can cause the evaporative emissions system to be damaged or rendered inoperative. The system is designed to control and process fuel vapor not liquid fuel. This may be the cause of your hesitation. At your next fill up, fill the tank until the pump shut off and add no more. Let us know if this remedies the problem.
mikes
  • 20,121
  • 50
