A 2000 Toyota Celica GTS 225k miles engine makes a mild rumbling/grumbling rough sound when accelerating slowly from a stop in drive or reverse only in the 800-1300 RPM band. Does not occur when in Park. Not sure what could be causing this mystery.
Already changed (with OEM Toyota parts) Exhaust gaskets, Plugs, all 4 motor mounts
Sounds almost like something in the engine is loose, pistons, value chatter, I am lost for an answer.
Hopefully someone has a thought, Thanks!
Joey
If you've never changed them, the problem might be one or more of the motor mounts. When one is worn out (especially ones which control the torque of the engine - like a dog bone type), it will start making strange noises when in the lower part of the RPM band from a stop. This can hold especially true if you are not really hearing it when up to speed. You can also feel it jerk a bit while taking off from a stop or hear it clunk (or dull thunk) when stopping hard.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 259
  • 508
