I got brand new tires in April. In July they started growing unsightly brown stains. Even after I wash them the stains reappear within hours. Kind of annoyed because they were hella expensive and they are really unattractive.
So 3 questions:
  • why?
  • is it possible to get rid of them?
  • is this something I could take up with the manufacturer to get them replaced?
purpleACR
  • 717
In my specific case, I called the distributor (Tire Rack - not sure if mentioning them is allowed, but it's a positive experience and I'm not affiliated)
They saw that the brown stain was in the same pattern on every tire and "deduced" that it was something on the tire, not a problem with the tire itself. They recommended using "Goof Off" to spray on the tires. I got the "Heavy Duty Spray" strength, mentioning this because there were about 20 strengths to choose from. I actually couldn't find it at an auto parts store as it's more of a home improvement item.
I tested on a small section and it seems like the brown has finally permanently been removed. It's been black for 2 days and actually the rest of the tire which was "black" before looks brownish by comparison. I plan to apply it to all 4 tires and will follow up if this changes.
purpleACR
  • 717
This sounds like tire blooming.
Why
Tire rubber usually contain an anti-ozonant which prevents UV damage to the tire (like you might see on a windshield wiper blade, it starts cracking). The anti-ozonant, when exposed to air, turns brown. Since the anti-ozonant is part of the tire's rubber, it continues to rise to the surface of the tire.
Usually you want to use a gentle cleaner. Using something too harsh may result in exposing more the the anti-ozonant to the air. Once it's cleaned off, dress the tire in a protectant.
Perhaps. If it is tire blooming then might tell you its completely normal and expected. It might be the result of a manufacturing issue, returning "within hours" is a bit unusual, I would at least make an inquiry to the manufacturer.
vcsjones
  • 133
You said you don't want that really glossy look for your tire, perhaps a low gloss tire protectant spray might be the best alternative to help your tire bloom issue if you are unable to otherwise fix the issue with simple cleanings.
