I hired a mechanic to replace my crankshaft pulley sensor. He ended up doing something wrong. We tried to crank it and it sounded like a dead battery and the sensor broke and hit the oil pump. Put a hole in it and both the timing belts broke.
How do I know if the valves are still good? Please help, I need to know what do. i have the parts to fix it but how do i know if the valves are still good?
DucatiKiller
  • 32,976
  • 150
  • 267
beth
I'm assuming you have a 4 cylinder.
You need to remove the valve cover. If the valves are adjustable then unadjust them until all the valves are free. Remove the spark plugs. Use a leakdown tester to induce compressed air into the cylinders. The tester will shows the amount of leak down and where it is coming from. If it's coming out of the tail pipe then bent exhaust valve. If it's coming out of the intake manifold then its a bent intake valve.
20 to 30 percent leakage is tolerable. Anything beyond that probably means bent valves.
vini_i
  • 16,115
  • 42
  • 64
