Hey i just wanted to ask about my girlfriends car she has been having problems with for over a year.. we had it checked but they always say nothing is wrong (usually because the car starts when they turn it off and back on) , the battery is new and everything seems too work fine...
So the problem, not every time but very very frequently.. when she gets in her car it doesn't start up. The lights and radio work perfectly fine. It isnt the battery especially since its quite new. the car makes NO noise when you turn the key.. just nothing happens. (usually she will wait a few minutes and keep trying.. eventually it turns on. except today.... she was stuck at her car for an hour and the engine didn't start)
We can only think it may have to do with the key or ignition? (the spare key does the same thing though) .. Can't think of the car make and model but its year is 2002, ill update when i get out of class so i apologize for that lack of info! Any ideas or assumptions on whats wrong and what too do.. Price tag for the fix? (money always a concern) thank you for reading!
*2002 Buick Lesabre
Ryan
  • 79
Turned out to be the starter. Needed to get it replaced. (what worked to get it started, is turn the key and tap on the starter in your engine at the same time)
Ryan
  • 79
Since:
  • your battery seems to be at full charge
  • the car runs fine
  • you dont hear the starter click (try to start)
I'd guess:
  • Your starter (solenoid) is failing or has a bad connection.
  • Should be < $600 total parts/labor if so.
To troubleshoot:
  • try jumpstarting the car when its not working (if it works, you can cross off the battery as a possible problem) Also make sure battery cables/ground have good connection and arent corroded
  • If the lights dim in your car, (but not considerably) that probably means that your starter is getting power and the ignition works
  • You -or your mechanic- can supply power/ground directly the starter/solenoid to eliminate all other possibilies
user3188168
  • 856
Due to the intermittentness of your problem and that it seems to be getting worse. Adding that there is no audible sign of anything happening, I would be looking at the ignition switch. It should be possible to take the switch mechanism off the back of the ignition lock and clean/replace the switch. If you do take the switch off, it morethanlikely will be possible to turn the switch with a screwdriver. You may be able to 'wiggle' the switch to find positions it will work/won't work, to verify it is the switch at fault.
If you do this, don't forget that the key also takes the steering lock off, so don't start the car and drive without taking the lock off.
HandyHowie
  • 25,681
  • 40
  • 76
