I unplugged the ABS fuse from my Toyata Yaris 2006 1.5 Hatchback CE to turn off the ABS system which was giving me trouble when trying to stop on snowy/icy roads.
The car stops much better now, so that problem is fixed. However the 50Amp fuse says ABS1/VSC1 and I don't know what the VSC1 stands for.
Is it something important I might miss later on?
Davide
  • 502
VSC stands for Vehicle Stability Control. It's the part which works in conjunction with the ABS to keep your vehicle stable during a bad braking situation. It also will help you in corners and such which might be a little too much for your vehicle. You decide whether it's important to you or not.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 259
  • 508
