I am just going into my final year of mechatronics engineering, and as a project for my spare time I am looking to convert a car to fully electric drive.
At the moment I am also toying with the idea of scratch building a small go-cart like vehicle, but this would require a whole lot more mechanical engineering, which I am not as well versed in as the electrical side of things.
If I were to convert a car instead of scratch building, there are obviously things in the car to choose for:
  • Ideally low mass
  • Road legal chassis and interior
  • Good space for batteries
  • General roadworthy-ness
  • Cheap
However I don't really know what type of car, or even how to look for a car which fits these criteria. Is anyone able to suggest what may be a good vehicle?
I do potentially have access to a 1992 Corolla H/B manual for reasonably cheap, just a little bit of panel beating required. Would this make an adequate choice, or is there something about it (and other similar vehicles) which make it a bad choice?
Thanks in advance.
EDIT: Just for slightly more context, I live in New Zealand, so by legal I obviously am referring to local laws.
Lui
  • 201
5 Answers5
I cannot speak to local New Zealand laws, but here in the USA a common vehicle for EV conversion is the Chevrolet S10/Colorado and other small pickups.
The combination of light weight, plenty of space for batteries, and a relatively simple design make these cars ideal. Moreover, since they have been around forever they are easy to find and cheap.
Plus there are all sorts of resources from people who have already made the mistakes, so you don't have to!
Tyler
  • 417
You could consider a rear engined vehicle such as the MR2 or MG TF. You then wouldn't have to worry about steering or the wasted space of the drive shafts. You could even have direct drive which would be nice as you wouldn't need any shafts or cv joints etc. You could also do some pretty neat things such as brake steer. Having two separate direct drive motors would negate the need for a gearbox or differential.
Although you might get more space for batteries and better weight distribution if you use a FWD car and direct drive. This means probably using driveshafts or heavily modifying the suspension/chassis legs to accommodate motors directly on the hubs. You could use the exhaust tunnel and the fuel tank location to store the batteries. You'd get better weight distribution this way but more work trying to fit everything in the engine bay.
Good candidates would be something Japanese because if I'm correct they're cheap and readily available in NZ but also because their electrical and CAN bus systems are very nice to work with. You could reverse engineer the CAN bus data and get everything working such as the instrument cluster, ABS etc. You could obviously do this with any vehicle with enough time and money but from my experience Japanese vehicles are much easier to 'hack' than say German vehicles with multiple CAN buses and such.
Newbie Noob
  • 2,792
You did not specify the era of the car you wanted to convert, but newer models are more complicated, so the simplest conversion may be something classic. One very common platform for conversion is a VW Type I, the Bug/Beetle/Karmann Ghia cars. They're light and there's room to work. However, you'd have to want to have an old car, as well as an electric conversion.
Aaron Brick
  • 370
There are many different enthusiast groups that have done this stuff. Here are a couple that jump to the front of my mind:
Haven’t been able to find much data on the green monster, but the article does reference a company that makes conversions kits, and you may be able to get some good information there.
As other mentioned above, I can’t speak to legalities in NZ (I’m in the States), but it shouldn’t be too hard to find some good data about what’s required for roadworthiness.
kyle_engineer
  • 3,289
You could start from an existing hybrid gas/electric. A vehicle like this will already have the electric motor and battery; all you have to do is remove/bypass the engine, rather than starting from scratch.
