I have a 98 Toyota privia and upon starting it the starter just keeps going. This only occurs in drive and neutral. The vehicle also starts in any gear. When I start in park the starter keeps spinning until I shift then it stops: same as neutral. Also if I nudge the shifter arm on the transaxle it stops.
I've already put in shims with no effect.
DucatiKiller
  • 32,976
  • 150
  • 267
Dee
  • 697
Two possible failed parts: The ignition switch or the starter relay. The ignition switch would be either not returning to run or has failed electrically. The relay would have to be stuck on or commanded on by the Security ECU. The security system is not supposed to turn on the starter only stop it from working. It is the least likely failure.
Fred Wilson
  • 11,667
  • 49
