I have a 1998 Ford Contour that has a check engine light. I checked the codes, and found:
  • P0171 System Too Lean (Bank 1)
  • P0174 System Too Lean (Bank 2)
  • P0401 Insufficient EGR Flow
  • P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
I think the main culprit might be a vacuum leak, and that the codes are related to the side effects caused by the leak. Are there any common hoses that I should check first? I remember we had two main hoses on BMWs that were usually the guilty party.
Mark Johnson
  • 3,931
  • 56
FossilizedCarlos
  • 3,249
The problem did end up being the fuel pump. Checked wires and fuses, but in the end it was a bad pump. The filter was also replaced, and can probably be blamed for the pump failing.
FossilizedCarlos
  • 3,249
