I have done a clutch bleed on my Toyota Corolla e120 2006 because I had some difficulties shifting out of 1st gear, I bled it through the slave cylinder and I noticed the fluid was dark black, I was checking the fluid level of course, after clear fluid was coming without air I closed the valve and now my pedal is soft and doesn't push the slave cylinder at all ... after a lot of searching for the problem I have noticed this on the other side of the master cylinder reservoir
the fluid doesnt flow into the compartment that goes to the clutch master cylinder (the brake fluid reservoir is common for the brakes and clutch) This is how it looks on the left side were I was looking when I was bleeding the valve.
So now I have air in the clutch system, and a blocked master cylinder reservoir, what is the best way to fix this?
