After recently taking my car to have a new rocker cover gasket fitted as it was badly leaking I noticed the guy who did it put a ton of gasket maker on the rocker cover when he sealed it, heavens knows why; I gave him a new gasket so it shouldn’t really be needed. Perhaps he used it to improve the seal.
What I am worried about is what if a piece of this gasket maker broke off inside the rocker cover what sort of havoc would it wreak inside my engine?
Thank you all for your time.
TMN
  • 2,309
ceefax12
  • 1,242
Rubber gaskets typically seal well. Cork ones are hit or miss. If the valve cover is stamped steel, its normal to use gasket maker rather than the gasket.
If a piece did fall off inside the engine, the oil would likely flush it down to the oil pan and it would be caught in the oil pickup's screen.
rpmerf
  • 8,458
