Any carbon steel thread that suffers from prolonged exposure to air, moisture and (sometimes) salt will suffer from rust, sometimes to the point where it creates problems.
While many fixes exist to remove a seized nut or bolt, I want to know if there are smarter fixes out there to prevent or at least minimize corrosion.
Engineering theory will suggest the following generic strategies:
  • physical prevention
    like applying coatings that don't let moisture reach the steel itself
  • chemical inhibition
    like sacrificial protection through zinc coatings
  • change of material
    like using a brass instead of steel
So, to reiterate my question:
What rust-inhibition strategies exist that are accessible to the average automotive DIY-er?
Zaid
  • 39,276
  • 50
  • 151
  • 294
First one that comes to mind is anti-seize compound. Some are a mix of aluminum, copper, and graphite lubricant. I use this all the time on my lugs nuts (2000 Toyota Camry with steel wheels) and it seems to keep the rust monster from seizing the threads.
cdunn
  • 9,326
  • 44
  • 76
