Okay, my car is frozen. it's negative Fahrenheit over here now. What I've tried: jump start, warm up starter, new spark plugs. nothing helps.
I guess the only approach is to heat it in the garage, but no available garage and tow at this time. so, I was thinking about covering the hood with rugs and putting heater underneath, but I'm not sure what kind of heater will help. Do you know what heater should I get so it's gonig to be enough?
How to prevent car from freezing if I have no block heater? do I need a tune-up? what kind of a tune-up?
user194076
  • 286
Please bear in mind that this is risky and you may not want to do it with an expensive car, or without a fire extinguisher handy. When my cooling system froze, I jacked up the front a bit, took a butane camping stove and put it under the engine, and left it lit for a few minutes. Solved the problem in a hurry, but I'd already ruined the water pump the first time I tried to start the engine with the cooling system frozen.
