I have a 2011 Chevy Impala. Once in a while the engine will rev and then kick into first gear. If I slowly press down onto gas petal it will not do this. If I start slow no problems, but if I put foot down on pedal hard it does sometimes. Can anyone tell me why this is happening?
Asked
Active
Viewed 63 times
I'm sure you've had this resolved by now, but as a GM trans tech I can tell you the most likely cause is a failed pressure control solenoid. The solenoid coil accumulates ferrous debris and becomes less effective. The pressure is commanded down at low speed and when the controller commands a higher pressure to take off, there is low pressure for a moment until the solenoid opens up more fully. The side cover has to come off of the trans to replace it.
Vince P.
- 21
- 1
