My timing belt broke on a 2008 Hyundai Accent and due to being broke I decided to try and fix it myself. I managed to get everything off, two slightly bent valves on the head which I took to a shop etc. While trying to prep the engine block for a new gasket I had to turn the crankshaft bolt. It would move about 30 degrees in either direction and then felt like an elastic was pulling it back. I was only using a short ratchet without a breaker bar or anything but it finally released and now spins freely.
I realized afterwards though the car had been put into 1st gear prior to this. The crank now turns freely whether in neutral or first gear. Is this normal or did I damage something in the clutch/gears trying to turn it over in gear? Thanks!
*yes, I know very very little about cars
*all belts were disconnected during this, head was off
DucatiKiller
  • 32,976
  • 150
  • 267
Dave
  • 93
It's fine
I did a similar job on a 2003 model recently. I kid car. Luckily, I didn't have any bent valves to deal with.
Turning the engine over with the head off and the car in gear won't hurt anything.
I know the exact feeling of elasticity you are talking about if you have the car in gear. I am assuming you had the front wheels on the ground when you did this.
Answer
You didn't damage anything.
DucatiKiller
  • 32,976
  • 150
  • 267
