My 2004 Audi a4 is making a gurgling noise from my engine. I am also having to constantly put antifreeze in it. Is this related? I know I'll have to take her to be looked at but can anyone tell me what I am to expect to hear of the issue and cost?
Asked
Active
Viewed 591 times
Open the hood a listen for where the gurgling is coming from:
- Find the water pump and listen there
- Listen near the radiator
- Listen near the coolant tank
- Listen near the top of the engine
Also, look for where your coolant is going:
- Look for puddles or stains where you usually park
- With the engine off, look near the belts for drops of liquid, stains, and spray marks (could be the water pump is leaking, if it is you need a new one)
- Look in front, behind and under the radiator for liquid, stains, and spray patterns
- Look at your two radiator hoses and squeeze them, see if it makes them leak (they need to be replaced if they leak)
- Look at the hoses coming from the water pump, squeeze them to see if it makes them leak (they need to be replaced if they leak)
- Look at your heater core hoses and squeeze them to see if it makes them leak (they need to be replaced if they leak)
tlhIngan
- 12,200
- 8
- 38
- 71
