Hi all I have a 2006 Vauxhall Zafira and have a problem with my rear passenger side lights, the indicator is working fine but no brake light or evening lights I have changed all the bulbs and still the problem persists. Im assuming its not a fuse as the driver side rear lights work as they should. Please can anyone advices me on what to check. Thank you
Because stop / tail lights are so important, manufacturers will occasionally split the circuit so that they have a fuse for each side of the car. That way, if the fuse blows, you don't loose all lightning so I wouldn't simply assume that it isn't the fuse.
With a bit of research, it points to fuse 7 being responsible for the right hand side tail light and fuse 25 being responsible for the left. The indicator circuit is on a separate fuse.
- 23,464
- 2
- 41
- 92
I had the same on my Zafira. It is usually a incorrect fitted light switch. When the switch is replaced it can happen that the bottom half of the terminals are getting pushed in. That cancel out the whole of the rear lights and the beam adjusters.
- 1
Easy fix:
park car
turn on right indicator with ignition off
then turn on left indicator then return to centre position all with ignition off.
All fixed.
- 2,315
- 13
- 40
- 59
