I seem to have run across a dispute about whether or not the various pulleys involved with a timing belt should spin freely or not.
For example, in this video the anonymous Internet expert says that a good t-belt pulley spins freely. Also, @Ben from this site says the same.
However, I ran across other opinions stating the exact opposite:
pulleys in good condition will stop very shortly after you spin them by hand. New pulleys will stop immediately. Natural friction of the grease inside the bearing caps are what slows down rotation.
What I've found the most convincing so far is this video in which a guy presses brand new bearings into his t-belt idler pulley and gives it a little spin and it stops very quickly.
Robert S. Barnes
  • 15,780
  • 72
  • 157
  • 249
I think both are stating the same thing, but telling it differently. Basically what I mean by this is, spinning freely does not need to mean it will continue to spin without stopping, but rather spins without binding. The main thing to look for in these pulleys is if, when turned, they are completely smooth to the touch and turn without much resistance, they are probably in good shape. The other thing to check for is to see if there is any movement in the bearings from side to side or have any play in it. The bearing should be fairly solid without any type of deflection. The idea that grease will slow up the bearing rotation is completely understandable and makes solid sense. I really just think the difference here is a matter of semantics.
EDIT: One thing I neglected to mention is changing out pulleys during normal t-belt replacement is a good thing. Most t-belt kits come with pulleys. Just like a water pump, I consider changing out the pulleys to be routine maintenance during a t-belt replacement. Just like with the water pump, it only makes good sense to replace them while you're in there changing out the belt. They may last you another 60-100k miles, but why chance it. The cost is by far cheaper than the alternative of a completely destroyed engine.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 259
  • 508
