I bought a peugeot 206 last year (a second hand one). Such car is my first car, I haven't owned one before, although I used to drive before such purchase. The car is quite old (I think 8-10 years), I never done a car servicing before, and I think I should do one to check that my car is still functioning well. I don't know if would make any difference do the car servicing in any mechanic, or a peugeot specific one.
What do they usually do when performing the servicing? Since the car is old would it make any difference in doing the servicing in a peugeot dealer or elsewhere?
Any general suggestion is appreciated. (I'm in the UK if that could help)
Thank you
user8469759
  • 185
I would always service a second hand car which is new to me so I knew the condition. You don't need to use a specific Peugeot garage, you may find an independent garage cheaper and for servicing on an older car, anywhere should be able to do it.
The alternative is to buy a Haynes or similar manual, some basic tools and do it yourself. You're best of doing this with a friend who is good on the tools to begin with and keep you right.
Steve Matthews
  • 23,464
  • 92
Generally speaking servicing means replacing consumable items after a specified interval (either miles, years or both) this can include things like engine oil, oil and fuel filters, brake fluid, spark plugs air filters etc.
The specific interval for a given item will be specified by the manufacturer and tends to cover things which are not expected to last the full life of the vehicle.
There are also things which should be replaced at specific points in the vehicle's life, notably the cam belt and associated ancillaries. Cam belts are especially important as while most consumables will gradually deteriorate a broken cam belt usually means a new engine.
There are also components which have variable wear rates such as tyres, brake pads etc which need to be inspected regularly and replaced as necessary.
Note that a service doesn't necessarily imply a full inspection of the vehicle and it is also a good idea to give it a reasonably regular inspection to look for any emerging problems such as corrosion, especially with reference to known problems with that particular model.
An MOT test will only check for road worthiness and won't flag up all maintenance issues, especially on non safety critical areas.
Chris Johns
  • 1,586
