2007 Escalade 6.2L, AWD, 140k miles
Is it possible to adjust the power steering pump pulley alignment (forward/back)? It's a few mm out of plane with the rest of the pulleys and tensioner, and the serpentine belt walks a rib off of the crankshaft pulley after driving a bit. Belt dressing (blech) keeps things working fine for awhile, but that's not a viable long-term solution, and shouldn't be necessary.
3Dave
  • 3,159
  • 25
  • 39
Don't think you can move the pump in/out but the pully can be moved using a special tool to remove and a not so special tool to install( bolt and nut and washers) to press pully in
cano
  • 833
So, after further investigation, I discovered that the tensioner pulley is also "too far back" by the same amount as the PS pulley.
In other words: the crank pulley has shifted forward.
The bolt holding the pulley on was only finger-tight. The IntarWeb buzz is that this happens a lot on Chevy small blocks. (L92 in my case.) Hopefully it's just a matter of getting a new bolt and finding someone with a torque wrench that can do 240 lb. ft. This is a torque-to-yield bolt; I'm surprised that it came loose.
Then again, it made it 140k miles, so...
Thanks to everyone for the help.
3Dave
  • 3,159
  • 25
  • 39
