tl dr: Don't use anything but the proper lug pattern/size.
The biggest problem with using a lug pattern which doesn't match exactly is you will most likely never get the wheel to align correctly. It will almost always be off center. The reason? The lug holes are sized to be centered exactly on the lugs themselves (seems obvious, right?). When the lug pattern is off, the first lug you tighten will throw the alignment of the other (in your case) four lugs out from the center of their lug holes.
Even if you were able to get all five lugs even (note I didn't say centered, because they will never be that way) in their lug holes, then only one little portion of one side of the lug will be engaging the lug hole correctly. If you get the holes to stretch enough to then be fully engaged to the lug nuts, then you're putting undue stress on the wheel. Adding stress onto the wheel where it doesn't belong can cause wheel failure, which could be deadly in the end.
Even the small amount of difference in wheel lug spacing can cause you big issues. Best idea ... don't even try it.
