I own Skoda octavia 2001 2.0. since last month, engine keeps stalling:
  1. while driving (for 10km or sometimes for 1 - 2 km in distance).
  2. keeping the car idle for 20 - 35 minutes.
and when it stalls, It cranks but does not fire-up. unless, waiting for 10 - 15 minutes, or push-start it.
special cases:
  1. when I am driving (over 60km in speed), I feel like the engine is holding back and loosing power or about to stall. As soon as I accelerate, it powers back (or lets say looks like gaining power to run again) and runs smoothly. This happens, in couple of seconds (like 1 - 2 seconds.). If I don't accelerate, engine goes off, but I can push-start it if I kept the speed over 40 km.
  2. sometime I drive for 4 hours without having this issue (this is rare other than having the engine stalling twice everyday).
Things I have done so far:
  1. I have changed the battery since it was kinda old.
  2. got the car scanned (no issues or fault were found).
  3. checked if the car still runs while the battery is unplugged (checking if the problem from the alternator).
  4. Replaced the fuel filter.
note:
  1. This happens since I changed the engine oil type to ( 20w50 ), while the car type is (5w30) but I have been told that the oil type won't cause this issue to happen.
  2. When the car stalls or about to stall, I hear clicking noise from the relay box under the dash. I checked the relays by just touching and found two of them were too hot compared to the others (which were kida cool).
Edit:
Forgot to mention a couple of things:
  1. I started to get the immobilise light before the car start stalling, but now I get the lgiht a lot lately (like 85% everytime I want to start the car). So all I have to do is switch off then back on for the light (warning) to disappear and be able to start the car. But I don't get the immobilise light when the car stalls or shut-off.
  2. When I force start the car when it's about to stall at low speed or trying to push-start it, I get the oil warning light and the car stalls (this happened to me sometimes).
  3. The car looks like to give me more driving time at cold weather. for example: at the morning (weather degree between 17 - 19 C)I can drive for more than 11 km (in distance (depends on weather)) then it stalls, but I can fire the car up after less than 5 minutes. But afternoon(as its hot 25 - 28 C), it drives me less than 9 or 10 km (in distance) and I won't be able to fire it up unless after 10 minutes of wait at-less.
  4. When I try to fire-up the car after stalling, I hear a crazy clicking from the relay box.
Edite: Scanned the car again and got the error code: 17978 (Engine Start Blocked by Immobilizer).
Jaz
  • 161
I have got the car fixed by replacing the crankshaft sensor. since then it's working fine.
Jaz
  • 161
