Sometimes , usually after a long run the starter turns very slowly like it has a flat battery. If I am lucky turning the key again a few times it will turn the engine at normal speed and it starts. It can then go for weeks starting normally before it happens again. I don't think its the battery because a flat battery would stay flat and it would never start till charged. I am thinking starter or solenoid. Any ideas anyone?
Asked
Active
Viewed 964 times
My bet is a loose or corroded connection. Leaning toward loose if it is intermittent.
I would try cleaning the battery, starter and ground connections of the starting system.
Nick
- 4,149
- 23
- 43
I had same issue on saab 9-3 2007. Problem was a faulty cables between battery and chassis. Garage has added additional cable connection between battery and engine (ground) instead of replacing complete wire lines and voila, it starts perfectly again.
Gregor
- 21
- 1
