This is a 2007 Dodge Caliber 2.0 CRD (which uses a VW Golf 5 TDI engine).
The valves on only 1 piston have come into contact with the piston, causing chaos in that cylinder. The other three are fine.
The engineers who overhauled the head say that the mechanic got the timing wrong because he never used the special tool (it's just a pin with a handle) to set the timing. Actually the guy used an Allen key instead of the tool to keep the timing belt gear in place, so I can't see what difference that would make to the timing.
If it was a timing issue, surely the valves on all cylinders would be affected, wouldn't they?
Is it not more likely to be a fault on the valve itself? A spring, or a material defect, or valve seating or something like that?
Please help, Thanks, Mark,(South Africa)
[![Only one piston was damaged
Only one combustion chamber shows any signs of valves contacting pistons
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 259
  • 508
Mark
  • 61
It sounds like your engineers are trying to pass the blame after they've messed up.
The valve(s) in that cylinder look like they have 'fell out' due to either faulty parts or incorrect fitting of the collets.
If the timing was incorrect the valves would not leave the head because the stems would bend and jam the valve into place.
There is also nothing wrong with using a allen key or bolt if the correct tool is just a pin with a handle.
No matter how bad the timing was out, or how bad the timing/tensioner failed it would be very rare for the valve to end up right inside the cylinder, normally the valve would just bend and damage the piston and/or head.
Newbie Noob
  • 2,792
I can only speculate, but perhaps the collets failed on the valves for that cylinder causing the subsequent damage.
I suggest this as if the timing was the cause then all the valves for all pistons would show evidence of contact / damage, as it is only one then another cause has to be considered in my opinion.
Solar Mike
  • 34,681
  • 59
