14
A dead battery is a common and serious problem. At a minimum it takes time to jump-start the car. But oftentimes a second car is unavailable, or there's no jumper cables, or a serial killer is chasing you and pounding on your window.
So why don't vehicles come with some alternate way of starting the engine?
Wikipedia says that the original hand-cranks worked but were inconvenient and dangerous for various reasons. I suspect that with modern engineering these handcranks could become safe, through the use of clutches and today's better-behaved engines.
There's also a spring starter for which, Wikipedia points out, "the most common application being backup starting system on seagoing vessels."
So with the constant push for reliability and features, why have I never seen a car that doesn't rely 100% on a battery to start? Imagine the marketing: "Never again be stranded with a dead battery!" Should be a hit.
Philip
  • 455
12 Answers12
As I’ve read, alternative starting systems nowadays used mostly in commercial, industrial and emergency applications, where it is mission-critical to get it started, such as back-up power generator in the hospital, fire pump on an oil rig, or a life boat. Redundancy is required in some of these situations; in others there is no other option even. There are commercial lorries, mining, quarry and construction vehicles, or generators in remote areas where the only system to start an engine would be the air (pneumatic) or hydraulic start. It is a lot easier to find compressed air than to find reliable electricity to charge a battery in some underdeveloped countries.
Most of those are, of course, are powered by Diesel engines, and do not even need electricity to operate, so some of the vehicles or machines would not even have a battery at all. And, by the way, there are, as I’ve read, hand crank systems on some of those: it is possible to use compression-release mechanism to make it easy to spin the engine by hand to get the flywheel going, then dis-engage CR, and kinetic energy stored in the flywheel should be enough to get it started.
On the other side of the spectrum would be open-wheel race cars (Formulas, Indy, possibly others, such as Le Mans or GT) that do not even have on-board starting system and need to have an external air- or electric start device to get going. Obviously, this is done to save weight — this way they do not need relatively heavy starter motor, and they can get away with much smaller battery which is used more as a current stabilizer rather than storage.
As for regular automobiles, there are several factors that prevent manufacturers from using redundant starting systems:
  • First of all, regular electric start is pretty reliable. All of us experience dead battery now and again, but mostly due to our own negligence. And in between, there are hundreds, if not thousands, starts the system handles without mechanical failure of the starter motor or natural degradation of the battery.
  • Secondly, although it is not high-performance racing application, the considerations of weight and cost still play an important role.
  • Modern cars use internal space rather efficiently, and there simply not many options to put another component, and have an easy access to it.
There are after-market systems allowing for that extra reliability for bigger utility vehicles like pick-ups for farmers or loggers and the like, but then again, that qualifies it as industrial application, because no one but Americans use those for getting to the office or snatching some milk in a neighbourhood shop.
theUg
  • 2,430
  • 43
Mine has just such a fancy emergency backup starting device. It's called a "manual transmission". Push starts great with a dead battery. Only downside would be the serial killer chasing me, and well, that's what they make concealed weapons licenses for...
Brian Knoblauch
  • 12,548
  • 35
First, sorry for my bad English.
I think it is because a modern battery is more reliable, from the car manufacturer's point-of-view, so they remove the unneeded crank system alternative.
Dead batteries may be very common -- yes, it got me multiple times on my old car -- but if you are maintaining your car regularly as the manufacturer suggests, you might (be forced to) replace the new one before it dies.
Battery technology seems to be advancing so much these days, some of them might be used in cars in the near future if it's really needed.
Nick C
  • 28,941
  • 56
  • 109
wizzup
  • 141
I drive a Land Rover, it has provision for a starting handle.
You'd be surprised how late they retained this, even on Range Rovers (classic) you can see the hole in the centre of the front bumper for the starting handle.
Anyway, most cars (with manual transmission at least) you can bump-start, which can't be done so easily with static machinery or boats ;) and car batteries & jump-leads are cheap & portable.
John U
  • 476
Some cars employ a two-battery electrical system. This comprises of:
  • a dedicated battery to supply the starting system
  • a general-purpose battery to power the rest of the vehicle's electrics
Now it might seem counter-intuitive to add complexity, there are some benefits to having a setup like this.
The one relevant to this question is that when the starter battery begins to weaken the control unit for starting the vehicle can switch over to the other battery.
From the Bosch Automotive Handbook:
If there is no charge in the general-purpose battery, the control unit is capable of provisionally connecting both vehicle electrical systems. This means that the vehicle electrical system can be sustained using the fully-charged starter battery. In another possible configuration, the control unit for the starting operation would connect only the start-related consumers to whichever batter was fully charged.
Zaid
  • 39,276
  • 50
  • 151
  • 294
The manual crank starter of days gone by was dangerous for the operator.
Also, when the electric starter began to become widespread, better batteries became a necessity, and I read somewhere that battery manufacturers gave a deal to car makers under the condition that they removed the hand-crank. The idea was, from a marketing point of view, if you have a reliable electrical starter with a reliable battery, what do you need a hand crank for?
Finally, because of the logistics of it, a hand-crank can only be installed in front of the car with a longitudinally-mounted engine. Transverse-mounted engines have become very common by now.
tlhIngan
  • 12,200
  • 38
  • 71
The old Vauxhall Viva I owned when I was a student regularly suffered starter motor failure, and it was a difficult component to replace because the mechanic had to move the engine out of the way.
I found that the simplest and cheapest solution was to park on the top of hills, and then bump-start it. I had the idle speed adjusted up so it wouldn't stall easily, and I survived with that for over a year. It didn't take much of a slope - most car parks have a slight slope, and you get really good at spotting the higher ground.
Who needs mechanisms when you have geography?
SusanW
  • 111
If you really wanted to avoid dead battery situations, the best solution is probably a second, isolated battery. Charge both batteries off the alternator, but disconnect the starting battery (via a relay) except when the alternator is running or the key is being turned. It's really stupid that cars are designed such that using non-essential accessories can run down the power needed to start the vehicle.
The reality is that it wouldn't actually be a good selling point. There's no use adding cost and weight to a normal every-day car when it's easy to keep your battery well-maintained and carry a $10 starter cable just incase.
Scott Hillson
  • 3,230
Personally, I just carry around a small starter battery kit in case of battery failure.
Something like this:
http://www.walmart.com/ip/Schumacher-XP400-Jump-Starter/15140202
Guy
If you are really worried about it, consider a manual transmission as you can potentially push start it.
Brian Knoblauch
  • 12,548
  • 35
Rob
I'll tell you why. Because a car manufacturer who tries to save $30 by not installing a rear-window wiper is not going to spend $100 to fit a new component to the engine.
Although, an industrious person may make a neat sum of money by making such a spring-loaded mechanical starter.
Captain Kenpachi
  • 8,888
  • 43
