I've always heard that brake fluid goes bad real fast (IIRC, it absorbs the moisture in the air).
What about power steering fluid?
Can you buy a large container and use it over the years? Or, like brake fluid, should you only buy what you need for one use?
Amazon Dies In Darkness
  • 2,315
  • 40
  • 59
Power steering fluid can be stored for several years in a sealed container. However the standards for power steering fluid vary by manufacturer and model year. The vehicle you are driving 5 years from now may not use the same fluid.
mikes
  • 20,121
  • 50
No, it is not as hygroscopic as brake fluid.
However, it can degrade over time - especially if the level is low and it gets overheated, It tends to go brown.
Normally the fluid will only need topping up if there is a leak - I still have a small (1 litre) container I carry in my car due to a previous leak which has been fixed.
Solar Mike
  • 34,681
  • 59
