So... as the title says. I accidentally added fuel cleaner to my transmission, which is currently leaking (meant to add stop leak as a temp fix if it worked).
I grabbed the wrong bottle and didn’t catch myself and now I poured cleaner into my system.
I couldn’t find anything online about what damages, if any, this will cause or if I can just ride it out and be fine. Or change transmission fluid immediately.
Thanks for any information!
Matthew
  • 183
You should drain this immediately.
The solvents may very well damage the seals etc in the transmission - you don’t make it clear if it is an auto or not.
So, drain, then refill and run for a bit then drain and refill again.
If you have not run it yet, that is even better...
Solar Mike
  • 34,681
  • 59
