What is the correct Power Steering Fluid for a 2001 Jeep Cherokee XJ?
I called a Jeep Chrysler dealership, and they said to not to use an ATF +4.
Then I went to another Jeep Chrysler dealership, and they said the proper fluid is MOPAR ATF +4. So I bought a quart. The numbers on it are MS-9602 and 68218057AB.
Do I have the correct power steering fluid?
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 259
  • 508
Amazon Dies In Darkness
  • 2,315
  • 40
  • 59
According to this website you can use:
Power Steering Fluid +4 (If unavailable ATF+4 is Acceptable)
Searching through things, it's the Grand Cherokee which requires the different power steering fluid and cannot use the ATF+4. This is due to it being an electric pump and supplying pressure to the cooling fan (or some such). The fluid used in the GC has friction modifiers.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 259
  • 508
-1
Fact, For jeeps 2001-2004 with hydraulic fans only use Valvoline power steering fluid Chrysler Spec: 5931/part number 799222
