I bought new tires in September. I have returned to the place I purchased them many times due to malfunctions. I feel like I am putting air in my tires all of the time. I know with temperature change that the PSI will change. I don't know if I should go back and have them remount the tires? It seems like my tire sensor is always on due to low PSI.
Asked
Active
Viewed 93 times
You need to get a old fashion tire gauge, fill the tires to the required pressure and monitor the tire pressure. Determine which tires are actually causing the problem, check them daily. Once you get some information on them you can go back to the installer. You could have picked up a nail somewhere or you could have a bad sensor. good luck
JACK
- 385
- 1
- 10
