I've ordered 2 new caliper carrier bolts but they won't arrive today as I needed. I've found a high tensile steel bolt of the same length and width but a difference of 0.25mm thread pitch and yes it's not an automotive bolt but I guess a general or construction bolt.
I'm confident they will screw in (maybe not though) could I get away with using these for a days or two light usage in the car or would they just not fit?
I know it's not ideal and when proper bolts arrive they will be swapped out, so in about 4 days time.
Andy S
  • 147
They won't fit! If, say, it's 1.25 instead of 1mm, you'll be trying to match 4 turns on the bolt to 5 on the caliper.
I strongly recommend you don't try, as you could very easily trash the threads on the caliper, and then it's helicoil or new caliper time!
Nick C
  • 28,941
  • 56
  • 109
