I have a '94 4th gen Honda Prelude. Driving home today I felt a distinct wobble through the steering wheel. I immediately thought I had a flat and pulled over but found the tyre is fine.
The wobble seems to get worse when cornering and is barely noticeable on straights.
Would anyone know what could be causing this? CV joint?
MeltingDog
  • 3,796
  • 76
Could also be upper or lower control arms from the sounds of it, before this started to happen did you hear or notice anything else? maybe a popping sound around corners? Bearings will make noise when going around a corner if they are wearing out.
Also I know some Preludes from this era had 4 wheel steering, does yours have this option? If so this could be the cause of your troubles, as it was a passive 4 wheel steering system. and Although it was more robust than the Super HI-CAS system found in Nissan's of the same era, it can cause vibrations if it is not in proper working order.
Twooni
