Looking at the MOT guidance regarding seat belts a "significantly stretched or weakened" rear middle seat belt would be a dangerous defect:
Defect 7.1.2(b)(ii) "webbing or flexible stalk significantly stretched or weakened" "Dangerous"
If this seat belt were removed entirely would this instead constitute only a major defect?
Defect 7.1.2(a) "A statutory seat belt missing" "Major"
Or is the middle seat belt not "statutory"? Meaning there would be no defect?
Appendix C of the above guidance would suggest that a:
  • passenger vehicle
  • weighing less than 2540kg
  • first used on or after 1 April 1987
  • with more than 2 forward facing rear seats
would be coded as "B, G and O". Code O seems to state that for forward facing rear seats it would be sufficient to have a
three-point inertia reel belt on an outboard seat and a three-point static or inertia reel belt, lap belt, disabled persons belt or child restraint for at least one other seat
That is, a seat belt on a not-middle seat, and one other seat belt. No requirement for a middle seat belt.
Have I interpreted this correctly? Would removing the seat belt result in a major defect, or no defect at all?
Aaron J Lang
  • 121
My experience (based upon converting campervans) is that the answer will depend upon the vehicle's V5 certificate.
If the vehicle is labelled on the V5 as a five-seater then it must have seat belts for five persons.
Taking the belt out entirely would, in that case, be a defect.
If you have a four-seater, you would be OK. But the manufacturer is unlikely to have fitted more seat belts than necessary.
I believe that removing a belt, reducing the number below the V5 figure, would also render you insurance invalid.
Chenmunka
  • 1,442
