I have built a machine that rotates a cylinder to weld it, I have to attache a negative pole to the cylinder which is connected directly to the rotor of motor, the motor is controled by a vfd , will that cause any issue to motor and vfd or not?
Most likely, yes, it will cause a problem. You need to isolate the VFD and motor away from the rotating cylinder or the welder will cause issues.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 259
  • 508
