I have a Dodge Stratus 2003 Sedan 2.4 Litre. The battery is not charging. Things we have done so far:
- Replaced alternator
- Replaced battery
- Replaced a related engine computer (assumably the PCM, but this wasn’t me)
- Replaced ASD relay
- Checked if new alternator was bad, triple passed bench test
The alternator is connected to the battery (I can read ~12.X Volts battery voltage on it when the car is off and there is continuity from it’s red lead and it’s body to the positive and negative battery terminals respectively), but it’s just not generating power (it should be ~13.X Volts). I guessed this problem might be the ambient temperature sensor near the battery going haywire, but I checked the OBD II data and the two temperature sensors I could find in there (without knowing which was what) both showed realistic values (84° and 78° as I recall, and the engine had just been running). I want to do continuity tests on the wiring, but I was unable to find a wiring diagram of the charging system: Sadly, this year and version seem to be one of the few that do not have a charging system wiring diagram for them in the Haynes repair manual I bought from AutoZone. Do you have any suggestions for further repairs or tests, or other sources of knowledge on the subject?
