2010 Silverado 1500; 4wd; 525,000km; Ontario, Canada
4-low and 4-high appear on the surface to act normally when selected, but the front wheels do not engage.
Details:
4-low:
- Put transmission into neutral.
- Use the 4wd knob to select 4-low. The light on the knob indicates 4-low was successfully selected.
- I can hear the expected loud click from under the truck, telling me something has happened mechanically to engage 4-low, which is good.
- Put the transmission into Drive.
- When driving, I can feel an hear that the truck is geared down, as expected.
- However, the front wheels are not being engaged. I know this because I got stuck in a small amount of mud and observed that only one rear wheel was spinning in the mud. I had a spotter confirm what was happening. Normally, I think at least one of the front wheels would have engaged too, and I wouldn’t have gotten stuck.
- I did an additional solo test by gunning the accelerator on a gravel/sand parking lot, and observed loose gravel only at the rear wheels, confirming the front wheels did not drive.
- Furthermore, the truck makes sharp turns well, which would not be the case if 4wd was working properly.
4-high:
Behaves similar to 4-low—the front wheels don’t engage. Of course, the difference between 4-high and 4-low is that 4-high doesn’t require the neutral gear step, and doesn’t make the “usual loud click from under the truck”, not even when working properly.
Question:
Do these symptoms point to an obvious cause? As a novice, is there anything I can easily check without a hoist?
