I would like to create a groove 3/4" wide and 1" deep in a piece of red oak 2x2, approximately 5" long (it is being sized to slip over a 1x2). I have a 1/2" router bit, and have successfully created a 1/2" wide, 1" deep groove in the piece; when I attempted to widen the groove with a second pass, the piece shot off of the router table.
What is the best way to enlarge the groove to the desired width?
I have tagged this question with "circular-saw" because it is the other possibly-relevant tool I have available.
JustInTheWoods
  • 239
kyle
  • 184
I highly recommend using a pusher and gloves for this project. There are lots of "brands" you can choose from, or you can use another board to do it. You only have one set of fingers though, and keeping them safe is more important than any project.
Pusher Stick
If you will note in the above picture, the board is being pushed forward and into the fence. This is an excellent way to get an even cut and retain control of the board. If you don't have a fence, you can clamp another board to the table and that will work almost as well
Once you have lined up and completed your first cut, move your fence back from the cutter 1/8th of an inch, and cut again. Then rotate your board 180° and cut again.
Cutting Diagram
Hope this helps!
DarthCaniac
  • 1,398
You are quite lucky that you were not injured. Perhaps you should take a step back and plan it out a little better. Proper shop safety should always be followed, even on small jobs.
For starters, the piece of stock you were trying to machine is far too short to be cut with a router safely. The minimum length that can be cut with a router is around 12". For these cuts, you should also be using a fence with a featherboard attached to it to prevent kickback. A push stick should also always be used. A rule of thumb is to keep at least a foot of distance between your hands and the bit at all times when the router is in operation.
Try starting with a longer piece, and then make all of the necessary cuts before trimming it down to length. You can keep the leftover piece, and use it on another project in the future.
Jason Hutchinson
  • 3,532
While a push stick is a great first step, one or more featherboards with a push stick really is the best solution here. When they are well secured, they will prevent nearly all kickback, either on a router table or table saw. When kickback occurs with just a push stick you are still relying on your body to resist the kickback, with featherboards kickback is resisted mechanically.
As an added benefit, featherboards apply constant pressure at the bit and will give you more accurate cuts.
They are basically free to make yourself with scraps, or you can buy ones that clamp to your miter gauge slots.
Featherboards
Also, pay very close attention to which direction you are feeding the wood, or moving the router. If the wood is being fed in the direction shown below it is called climb cutting and can be very dangerous. In a climb cut, the bit is cutting on entry and has the effect of pushing the router away from the workpiece. If not resisted by the operator, the bit can exit fully from the cut and "climb" its way along the workpiece. For a router running at 10,000 rpm, this can mean a sudden loss of control and high risk of injury.
JustInTheWoods
  • 239
Here is how you can use a circular saw to cut your 3/4" groove very accurately and easily. You can certainly do it using a router table but it will take a bit more time to set up properly and I'd say the circular saw is arguably safer. Using a router, you would also need to be sure you take multiple passes, increasing the depth of cut each pass. This method can be done at the exact depth in one shot: https://www.youtube.com/watch?v=KNX9Y2cyRhk
In your case, since you've got a narrower piece than the base of your saw, you should sandwich it flat between two other pieces of same-height material so the saw has a wide base to move across.
An ideal way to cut your groove would be using a stack of dado blades and a table saw but you didn't mention if you had that available.
tbox
  • 769
