I am working with an electrical socket and I need extra length on the ground wire. It doesn't seem unreasonable that I can attach an extra three inches to the existing one and attach it with a copper wire crimp. Does anyone see a problem with this?
I have no extra slack on the rest of the wires, so I am not able to pull it through any further.
This is the type of crimp I am talking about, but I guess it's crimp sleeve
oscilatingcretin
  • 5,932
  • 99
  • 114
Technically, you should twist the extension bare ground wire to the short one and secure it with one of the copper crimps like you have pictured. A wire nut certainly would work , but it should be green. Practically speaking, either way will work and be safe, just a matter if you want to follow current NEC standards.
shirlock homes
  • 58,628
  • 87
  • 168
As an apprentice electrician... years ago, I was trained to use these crimp sleeves on all of our residential installs. So, I have and still do, use these crimp sleeves for the purpose you described. The important thing is to install the device per the manufacturers instructions. There is a prescribed method for installing these things and you have to follow the method or no you shouldn't use it for the purpose you described.
the following link is a cut sheet for the "Ideal" brand product and doesnt show the method of installation,
https://rexel-cdn.com/Products/Ideal/30-410.pdf?i=43A07F9B-9189-41EC-90AF-6D1F4AA0126B
This link shows the installation instructions which should accompany the sleeves when you purchased them. https://media.distributordatasolutions.com/ideal/2018q1/936d9a932e1d05817dd91ffa8235e01ed2058e31.pdf
Basically, you spin your ground wires together 3 times using either the crimp tool or a pair of linemen's then crimp the sleeve over the twisted wires.
-3
Based on my research the anawere is no. There are crimp sleeves that are copper with tin plating which I believe would eliminate the dissimilar metal issue of joining aluminum to copper wire but, you still have the issue of aluminum wires excessive expansion/contraction properties when heated by current that, I believe, is why there isn't any wirenut currently approved by CSPC OR NEC to join aluminum wires period. The only crimp system is copalum cold weld crimp pigtail system by Amp-tyco but it's only available by specially licensed installers. Your only certified way to join your two aluminum wires to a copper pigtail is using alumicon connectors that srew clamp each wire in a dedicated port.
I historically used the abrasion in the presence or non flammable anti oxidant grease but it is slow and not a preferred method, any more, because of the aluminum expansion contraction consideration.
My personal approach when it is impossible to either expand the box ( i.e. phenolic 1 gang boxes or fit 3 alumicon 3 port connectors in the box, and since the ground shouldn't be seeing any persistent current, is to coat the two ground wirers with non flsmable antioxidan, abraid them with #240 emery cloth (also coated with the grease) and then use 1 or 2 tin coated copper crimp sleave to crimp the 2 aluminum wieres to a copper pigtail which was already connected to the recpticle ground, fold in the wirers and device into the box and call it a day. There is a 1/2" box Extender ring if you don't mind turning the recepticle to a raised one.
