We just moved into a new house and I found out they used Cat5 to run the telephone network in the house. I found the junction where all the network/phone lines come together and disconnected all the wires that were capped together.
I put a wire tracker at each wall port to determine which cable end in the junction box belonged to which port and labeled accordingly.
Here's my problem: I swapped out the RJ11 port for an RJ45 and wired it up in the B pattern. I then put another RJ45 port at the end I determined was the matching end and wired it up in the B pattern. I plugged a switch in one end and a router in the other. The switch and router link lights do not come on, but my wire tracker makes it clear that I have the correct wire in the junction box. I tested that the switch and router should be able to talk just fine by taking a long ethernet cable and plugging them in using that- link lights galore.
One last thing to note, it appears that there may be some current running on the line, somehow, even when nothing is plugged in. My wire tracker lights up, but doesn't buzz, over every single wire in the junction box, and even at the outlet in the room before I have plugged anything in to pass a signal.
How is this possible when I've disconnected every wire from each other in the junction? I just assumed that from wall jack to junction box would be a straight shot and this would be easy as cake- 12 hours later, not so much.
manyxcxi
  • 141
First obvious problem- you haven't wired it correctly. You have proven connectivity works with the long Ethernet cable so the fact you are failing to get lights shows that you need to sort this.
Also getting signal on all the wires shows something is connected somewhere. Could be a splice as Steven mentioned, or some other problem. Is it even cat-5 cable?
In general what I do is use the existing wire as a pullthrough and replace it with known good cable.
Rory Alsop
  • 3,096
  • 46
A trick I use: many cat5 cables come with feet markers printed right on the jacket. If I can see "252" on the one end, and it's about 50 feet to the other room, I'd expect to see 302 or 202 at the other end.
Cat5 should be wired in a star pattern. But if they were using it for phone, perhaps it took a side trip to another jack. But even if it did, you should be able to splice all 8 wires and it will look ugly but work fine.
Bryce
  • 11,057
  • 77
  • 120
If you didn't test all 8 wires in the cable, it's possible that there is a daisy-chained phone jack somewhere in the middle, passing through only two pairs. Take a look at how standard phone wiring works.
One way to convert these daisy-chained RJ11 ports to RJ45 is to terminate all Cat5e cables in an RJ45 female port. Then you can install patch cables or switches at each jack, depending on whether you want to pass the signal through or connect additional devices.
Andrew Mao
  • 143
