I can see a few reasons, but so far none are compelling.
Depending on how large plumbing access holes are you may want to ensure that it doesn't shift. (I did mine with 1.5" holes for water lines, and 3" for drain, and installed a larger piece of vinyl tile as a mouse arrestor.
if you don't have a cabinet with a built in back splash, being able to run a bead of caulk along the back edge keeps crud from making a bid for a life of obscurity.
On the other hand:
Free cabinets allow you to shift one over 3 inches to do the side of the stove and the floor.
Free cabinets allow you to pull them away from the wall at painting time.
Free cabinets make life a bunch simpler when it's reflooring time.
Sherwood Botsford
  • 3,612
  • 47
5 Answers5
30
Nearly all the reasons you proposed for leaving them free are rare occurrences. (I'm not sure what "doing the stove" means. Cleaning?) On those occurrences it's fairly easy to pull a few 3" screws and do your business.
To my mind they don't outweigh the reasons you offered for anchoring them, which mostly involve stability (safety) and a quality feel. Most folks want a sense of built-in cabinetry, rather than freestanding furniture, which can wobble and shift with use.
How about not screwing up your countertop seams, by moving? How about not collapsing sideways due to weight of porcelain + iron sink and granite counter? (I live in earthquake country...) How about not making drawers and doors not work correctly by being out of square? True, the back panel of cabinets ought to act as a shear brace... How about not having gaps develop between adjacent cabinets?
BTW here's another question about this.
Tom Hundt
  • 321
In the UK at least your cabinets will all be screwed into the underside of your kitchen worktop (except stone worktops which will be glued down with silicone), and also all screwed to each other, so they will all be rigidly connected together anyway.
Cabinets may also have utilities such as gas and electric services passing through them. For this reason moving them could be dangerous as it could pull out a cable or damage a gas pipe.
Having all the cabinets rigidly in place also makes it easier to install a worktop without moving your nicely levelled cabinet tops. Besides, if you move the cabinets later, what's holding up your worktop? Maybe things work differently in the US.
Free cabinets would also spell doom for your nicely your nicely aligned cupboard doors. You would probably need to readjust every time you moved them. Because of expansion you would also probably have to have a bit of a gap between them to have any hope of getting them out and back in again.
I personally have enough trouble getting the damn built-in appliances in and out never mind all the cabinets as well.
crobar
  • 201
Interesting question and comments. A few things strike me. First, a lot depends on the type of cabinets. Framed vs. frameless in particular. Both types have their merits, and I am not going to get into that debate, but most frameless cabinets I have seen on the market today rely on the wall to some extent for their strength and stability. In both cases, a floor that is not level or has waves in it can cause a cabinet to rack, drawers to malfunction or joints to separate when weight is placed on the cabinets. Maybe this is not necessarily a heavy countertop, but someone sitting on the countertop. As far as I know, all cabinet manufacturers recommend shimming the base cabinets at the floor to prevent this. In my experience it is extremely rare to find a perfectly level floor or wall. (and by extremely rare, I mean I believe it is possible, but have never personally seen it.) If the cabinets are not shimmed and secured to the wall, there is nothing to prevent the cabinet & shim system at the wall or floor from moving around.
The second issue that strikes me was partially mentioned before and that is door and drawer front alignment. In both frameless and framed applications, the cabinets are typically clamped and screwed to each other where 2 cabinets meet. This is to align the face of the cabinets and eliminate gaps. Then the drawer fronts and doors can not only be squared to the cabinet, but aligned with each other. If the cabinets are not secured to the wall for stability, any movement of a cabinet runs the risk of cracking the material around those connections.
Third, if the cabinets are not secured, finishing with any trim will be nearly pointless. If you want to run a piece of scribe to hide the gaps where the cabinet meets the wall or quarter round at the base, those would have to be connected exclusively to the cabinet and will likely not survive without being removed if the trim spans over more than one cabinet.
One final thought, I think the idea of free floating cabinets would technically work without running the risk of damaging the cabinets if the cabinets are of very high quality. Perhaps the type with feet as opposed to a continuous baseboard would do better. However, you would be taking an expensive cabinet and giving it he feel of a cheap installation. In my experience, I have seen a skilled installer who cares about the craftsmanship of his work take a set of the cheapest production cabinets you ever wanted to see and make them look like they belong in a million dollar show home. Unfortunately, I have seen a lousy installer butcher the installation of some very nice cabinets to the point where they were ripped out and re-done by someone else (rightfully so).
Whatever you do, I wish you success in your project!
WoodAirGrille
  • 1,404
Every answer you've gotten as to fixing the base cabinets and leveling them to the floor and walls is correct and important.
Your desire, for whatever reason to be able to move the cabinets to paint, clean, etc. gave me a good idea for you. U should look into commercial kitchen cabinets on wheels. The wheels allow for movement to clean, and even rearrange them. The only "fixed" cabinets would be the sink (water and drainage) and stove (gas or electric, and required ventilation). Good Luck to you.
Bob
  • 76
